Old 27 May 2009, 08:02 pm
CREWZIN CREWZIN is offline
Default Re: AUTOMATIC TRANS SERVICE RECOMENDATION::
You say it was serviced. Was the pan dropped, filter changed and only about 4 Qts added? The whole system holds about 16 Qts and needs to be flushed to change the whole thing. A lot more expensive so it's up to you. Changing it just the way your doing it (4 Qts) is better than nothing so if you don't want to put out the extra, keep up the smaller changes.
Wait for other responses to get more opinions.
