Old 30 May 2009, 02:45 pm
invidious invidious is offline
Default Headlights wont turn on but highbeams work uhhmm ok
Ok frustration has fully set in i have an ongoing problem that seems to be getting worse. 2001 PT 83k miles. At first my right headlight went outwhile driving at night i noticed immediately. So the next morning i checked the fuses and found that someone shoved a 25 amp fuse in the #18 postion where a 10amp should go. So i pulled it out and saw that the fuse was melted and not blown it also melted the slot in which it sits in not bad enough to where it will not make a contact by a fuse though. So i pulled the 25 out and replaced the #18 and #19 fuses with new 10amp's NOW I GET NO HEADLIGHTS WTF? My highbeams work perfectly though. So i took it too advanced auto and the guys there were baffled they had 3 of them out there at once checking relays,fuses etc. "Props to the guys at AA they know customer service btw". So know i have no functioning headlights and only highbeams we verified that the fuse panel was working with a multimeter so that doesnt seem to be the issue. Any help whatsoever is much appreciated i just cant afford to take it to a mechanic and this car is my job so many thanks to all who can contribute you all rock!
