Re: Headlights wont turn on but highbeams work uhhmm ok
I was thinking "multifunction switch" ,(if you have any problems with PT Cruiser lighting, always check that first), but now with all that overcurrent melting going on, it might be more than that.
You should probably get a continuity tester, disconnect the battery and see if the load side of the that circuit is grounded out. If it is, you probably are going to have to find the short and fix and/or replace wiring or harness parts.
You might want to just replace the multifunction switch and prey that's it?
Good luck!
srg
