Steering wheel moves side to side up to 45mph?
'06 PT - auto - 31K - Well I just bought and picked up my '06 PT today and noticed from a dead stop to about 45mph the steering wheel moves side to side by itself under even the slightest acceleration. There is a slight vibration in the steering wheel when cruising 55 - 70mph and also I feel a very slight vibration thru the pedal in the front end. I'm guessing I have a combination or all four of the following issues.
1.) Wheel balance needed in front tires
2.) Check brakes...possible rotors warped or need to be cut
3.) Some type of front suspension/steering issue
4.) Bent rim(s) I'm assuming the front rims ....Can a mechanic check for this???
Any insight felas...Still some warranty left...will it cover any front end rack & pinion repairs and suspension issues?
Also did the base models come with keyless entry or anti theft. All I got was two keys but noticed only one keylock which is usually a sign of keyless entry key fob. How much are they?
66CUDA
