Re: Steering wheel moves side to side up to 45mph?
The wobble is most likely a bent rim or a bad tire. If it has the original GoodForayears then that is very likely. Could also be a bad axle.
Base model's did not have keyless entry. If you don't have power locks then you don't have RKE.
