Re: 02 PT overheating?? grr...
well now im leaning towards a head gasket, for these reasons. someone correct me if im wrong on assuming this.
1. i bleed the system, and i take it for a drive and i still build up pressure a lot of it in the system.
2. still is overheating, goes up and down around the halfway mark till finally it climbs and wont go down.. much like air in the lines would do.. then the collant boils out and im low on coolant yet again..
im confused.. there is no oil in the coolant, no coolant in the oil.. only leak is from the overflow tank when it boils out. or when im bleeding the system which is natural.
im out of idea's... where is this pressure comming from?
