Re: Oil not draining, dipstick shows full with plug removed?
Sounds to me like you are going to have to take the pan out like CREWZIN said. I would not run or drive the car tell you do, if something is in there blocking the drain plug there might be something blocking the oil pump, If it is then your engine can seize up.
