Old 02 Jun 2009, 01:52 pm
CREWZIN CREWZIN is offline
Default Re: air conditioning not working
Gigi,
First, stay away from that dealer if possible. I'm not sure if you really needed the timing belt and water pump changing when you did (don't have enough information) but as far as your overheating, the odds are it was either the thermostat, radiator OR cooling fan that you needed, NOT ALL THREE.
Since you haven't tried your A/C since they worked on it, it's possible they messed that up also since most places have to move the A/C lines to change the timing belt.
You should also run the A/C, even in winter to keep the seals lubricated. So, in any event, you need to have the A/C freon level checked out. If could be as simple as a recharge. Can't give you an estimate but there are places around that will check the A/C for free and only charge you for the parts (including R134 freon) that you need.
Look threw the yellow pages for such a place.
