Re: 03 dream cruiser turbo
check your valve cover to airbox hose. it sounds like you have air pressure build up in your valve cover. it's a hose that come off the right side of the valve cover and goes into the airbox. it is an oil blowby line. it could be caked with old oil and blocking flow,causing the pressure build up in the valve cover.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
