Thread: Over heating
Old 10 Jun 2009, 02:37 pm
Cowboyfann Cowboyfann is offline
Default Over heating
02 non turbo PT Cruiser. Had leaking coolant bypass tubes replaced. Car ran fine and cool under all conditions. When I got car back it overheated going up a steep grade with AC on but would cool down by turning AC off. No problems with AC on or off except going up grade. Rad. flushed twice, new rad cap., new high and low relys, fuses good, new fan (old fan did not work on low speed), new thermostat and sensor. Dealer now says that AC condenser is blocked and is causing heat to go through radiator which is causing it to run hot and high pressure line at 400 psi. Dealer wants to change condenser for $600 but will not guarantee problem will be fixed. Noticed they used green coolant and I tried to find red Chrysler coolant to replace it but could not find it. Used orange all purpose coolant. can this be the problem? Under a load is the compressor supposed to shut off and if so how can I check for that? Any suggestions? I am out of patience and ideas Thanks
