Thread: hood release
Old 16 Jun 2009, 10:56 am
CREWZIN CREWZIN is offline
Default Re: hood release
garciaag,
Here's your answer.....
If you look in the grill you should actually see the hood latch mechanism and the cable coming out of it. Now the cable has two parts which I'll call the wire and the sleeve. (The wire runs inside the sleeve) Take a long screwdriver and pry the sleeve away from the piece holding it in place. The wire should still be connected to whatever it's connected to. Now just pull the cable with a pliers or channel lock and it'll open.
Now this is on a 2001 P.T. Cruiser, non-special edition. I'm not sure if this same procedure will work on newer models or Limited and Touring editions.
