Old 16 Jun 2009, 07:30 pm
ron2004gt ron2004gt is offline
Default Re: Service-Manual for Mopar 6-CD player?
Originally Posted by CREWZIN View Post
I just Googled and searched other forums because I had heard of your problem before with the battery being disconnected and everything I came up with were problems, no answers. If someone did come up with an answer, they never came back to the forum to say what it was. Sorry.
I did the same searches a lot before I posted this thread with the same non-results. Since the radio does not show a selection for the CD player now I believe the problem is a setting that introduces the CD player to the radio.
If I would have thought about I could have kept power to the battery cables
while I swapped the battery but unfortunately never crossed my mind I would get burned like this.
I soldiered in a new negative cable to be battery and that took some time to go find the right part for. Yep I did it right and now after some months there is absolutely no corrosion on that terminal. The oem-negative terminal always was really bad with the mixed metal terminal ... a design flaw for sure.
BUT I had the battery disconnected for at least an hour maybe two.
