Thread: Fusion Audio
Old 23 Jun 2009, 08:34 pm
chris15's Avatar
chris15 chris15 is offline
Default Re: Fusion Audio
Your problem is gonna be wiring it. It's great that it's free and all, and if you have it wired correctly, that's even better. But you have to do your research. If you wire an amp that needs to sense a 4ohm load to a 2ohm sub, you're not going to hear anything. And vice versa, if you wire an amp in a 2ohm setup that is only supposed to run at 4ohms, say goodbye to your amp. It's tricky. That's why I like mono/dual-channel amps. Much less complicated.
Edit: Thought about it after I posted this.. it's not necessarily that it's COMPLICATED, it's simply that 4-channel amps weren't made to be bridged. In all likelihood, you'll be able to bridge it to two channels, but I don't see any way for you to bridge all four channels into one.. And 65-watts of power through your sub is most likely not gonna bring a smile to your face..
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
