Old 28 Jun 2009, 08:25 pm
PT_Cuda PT_Cuda is offline
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Removal of Interior???
Originally Posted by calicruiser View Post
Can anybody tell me how to remove the covers in the front area, id like to paint it ALL, but idk how much work that takes...but for now just the airbag plate, center console and gauge plate
You sure about this?
This is my GT when I painted the dash panels, if you are brave and can handle removing the passenger airbag you are good to go. I hadn't gotten dash panels out yet, I was taking a break after treaing out my entire dash to get to them.
The following instructions will work for a 01-05.
The center bezel is easy, I would start there, if you feel comfy with this I will be happy to give tear down instructions for the dash panels. But the car is not driveable during the dash panel mod!
Center Bezel removal:
Trim stick in the window switch at the top, pull down and out, it will pop out the window switch. Disconnect the switch from the harness .
Behind where the window switch was remove the screw that is top center set aside.
Pull off all A/C knobs 01 only all A/C control knobs must be straight up in order to come off. All other years it does not matter.
At this point the center bezel is ready to come out
Just pull and work your way around the edges, it is held in by snap clips they can be a bit tight so once you get one out just work your way around so you don't bend the bezel.. But getting it started may require some force.
Remember the A/C vents are attached and will come with the bezel.
They are removed by just taking out the two or three screws holding them in place on the back.
Reverse process to replace and your car is driveable without the center bezel in it. At night you will get lots of light thrown by the dash lights, but you can deal with it for short trips. Just plug in the window switch and off you go..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
