  #35 (permalink)
Old 30 Jun 2009, 08:45 am
THS_Cruiser03's Avatar
THS_Cruiser03 THS_Cruiser03 is offline
Default Re: Turbocharging my PT
Originally Posted by pteezer129 View Post
What about when I rebuild the engine I put some performance componets in. Crankshaft, camshafts, cylindar heads??? Can I amp up the compression ratio?
What about the Mitsubishi/Chrysler 2.5L V6 form the Dodge Stratus. If I'm gonna take the engine out of the car, I might as well see if the engine is compatible with the existing equipment in the PT and the weight should be about the same.
You can absolutely do the first option. Research the parts needed and the costs involved to make sure your up to it. But building the motor from the ground up is ideal. I couldn't do that with mine because I had to have the car back on the road within three weeks of tear down. If that's not a problem for you don't worry about it.
Personally, I think you're probably not understanding all the complexity involved in dropping a 2.7 or 2.5 V6 into a PT.....Have you looked under your hood lately? That engine bay is tight man! I couldn't even find a good place to mount my HID ballasts!
Doing a NA PT turbo kit would be WAY easier than doing a v6 swap IMO.
Base '03, Light Almond Pearl Metallic - Modified 2.4 na w/ported head, 10.4:1 compression ratio & Crane #10 camshafts - 4 speed - Energy Poly bushings - Napa ceramic pads & Ultra premium rotors - Rotora Stainless brake lines - Extreme Acc. Xenon HID 8k low & 6k high
Dark taupe & Ivory Interior, Factory CD w/Sirius Stratus 4, Power Acoustik 840w 4ch, Boss 200w 2ch w 10" bandpass sub, 2 sets Phoniex Gold Matched comp. speakers
Rolling stock: 16" SE A7w 225/50/16 Kuhmo Ecsta AST - One of the nicest Light Almond PT's you'll find
