Old 03 Jul 2009, 01:13 pm
CREWZIN CREWZIN is offline
Default Re: '07 Convertible Pulling to Right
Diane,
First and easiest things to do is rotate the wheels and make sure the air pressure is correct (all the same) in all 4 tires. Then work from there.
Whoever rotates them for you (or you if you do your own work) check out the tires for uneven wear or cupping. Put the best 2 on the front.
2000 PT. 100,000 miles, Original Owner
