Re: '07 Convertible Pulling to Right
Hi, you need a second opinion as maybe the car has been hit, Have someone follow you down the road to check wheather it crabs in otherwords does the car have a tendancey for the left rearwheel to hide the left front and can you see the right front while your driving directly behind you. this is a sure sign of some rear axle alignment problems often caused by bumping a curb with the right rear wheel. Another test you could do is to mesure the wheels from center to center from front to back . it only needs to be a small difference with the left side being slightly longer to cause the drifting right .this is not normal and can probably be fixed at any respectable bodyshop. good luck and hopefully its something simple like the others talked about. Ray Newton Pteazer.
