Old 08 Jul 2009, 03:16 pm
CREWZIN CREWZIN is online now
Default Re: What does the error code PO 138 really mean?
There's couple of reason why you got that code but it should mean that something wrong with the upstream 02 sensor.
You can try replacing it yourself, or have a mechanic put a scanner on your PT and pinpoint the exact problem. This is from PT Do-It-Yourself.net ....
P0138 -1/2 O2 Sensor Shorted To Voltage - Oxygen sensor input voltage maintained above normal operating range.
Possible causes:
Intermittent Condition
O2 Sensor Operation
O2 Sensor Signal Shorted To Voltage
O2 Sensor Signal Open
O2 Sensor Ground Circuit Open
PCM
1/2= O2 sensor before the cat.
2/2= O2 sensor after the cat.
