Re: Bleeding the @#$%!*# Brakes...
Really easier with a helper. Even a kid can do it as long as he can reach the brake pedal.
Ask the helper to depress the brake pedal 3-4 times in a row and then keep it depressed.
While it's depressed, release pressure by unscrewing bleed screw a bit and then screw it back.
Ask your helper to pump the brakes again, same thing, unscrew/screw the bleed valve.
Do it 4-5 times or until you see only oil coming out from the valve.
