How to retrieve fault codes.
This "trick" works on all models of cruisers.
1. Place the key into the ignition.
2. Turn the key towards the windshield (without starting the engine) and back again.
3. Do the above 3 times and with the last turn the key left pointing forward (towards the windshield).
4. All three turns should be made within 5 seconds. (it's not hard).
If you did it right, in the middle dial where the odometer is, the fault codes stored in the computer will come up. Example: P0138
If there's no codes stored in the computer, it should read "done".
That's it. Pretty easy.
