Old 12 Jul 2009, 05:37 pm
PT_Cuda PT_Cuda is offline
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: Damn NJ Inspection Stations!!!
Originally Posted by CREWZIN View Post
How would that work exactly? We have a fault like this: P1684 - The battery has been disconnected within the last 50 starts. But 50 starts could be 2 months ago, or more, depending on how often the car is used, so how could you tell if it was "just" cleared or 2 months ago?
What happens if you just put a new battery in, or had some service work that required that the battery be disconnected. Half the procedures in the Haynes and Chilton manual start off with "disconnect the negative battery cable".
That's a stupid thing to do, fail someone for the battery being disconnected.
So, I just spent $1000 to have the timing belt replaced before anything goes wrong (preventative maintenance) and then I take it in for inspection and you fail me because the battery was disconnected?
The PCM kicks back that the emissions systems are not ready and have not been through enough cycles to say they are functioning properly and give readings.. =Big Fat You Fail at inspection/smog time..
Been there and through that with my mom's PT last month.. She didn't know since we just replaced the battery and she doesn't drive it much.. So I get to drive it like I stole it for almost a week it was ready and took it to have it retested.. Passed with flying colors..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
