Old 15 Jul 2009, 12:18 am
pppt03turbo pppt03turbo is offline
Default Re: LQQk -> new rear liftgate treatment
starting from the license plate light, i used a string to help stay/guide exactly center (underneath). i marked the center point, then just drilled a hole through the underside plastic lip.
because its mounted on plastic, i had to make a separate ground wire using a solder-less connector around the threaded base of the cowl light.
after mounting the light - for ground - i tapped into the muffler's fat ground wire/10 mm bolt (rear muffler hanger).
the cowl light's (+) wire is tapped into the left taillight's "running light" (+) wire (black/yellow stripe).
good luck with your application captcueball. post a pic when you're done.
