Old 15 Jul 2009, 08:41 am
Hooligan Hooligan is offline
Default Re: dome light doens't turn off till i turn on the car...
That is a normal thing. You didn't say what year and the following may apply to all PT's, at least 2006 and up. On your left gauge pod there is a button that can be used to check out side temp, miles to empty etc. If you push the button enough you will come to personal settings, you need to press & hold to scroll thru and you can adjust numerous settings. I do believe that you can adjust the interior lamp, I know you can adjust the time the headlamps stay on after you shut the PT down.
