Originally Posted by 03GTCruiser
Definitely. $200 for stage 1, $85 for injectors, Don't remember what the gasket cost me, but wasn't more than $15 if I remember correctly. So, $300 to get and install what was needed for stage 1. Took about 20 minutes start to finnish with the install.
Then drove it for about 10 miles without speedo or odo (*see foot note*) keeping it WAY out off boost till I got to the dealership to put the Pinion Factor in and since it was there for that, I had dealership do the transmission quick learn procedure while it was there. took them about 45 minutes but cost me $115 for the 1 hour "Diagnostic" fee that they had to charge me to connect it to the computer.
*guys and girls, Just remember when you install stage 1 that you might need to have the following done as well after installing the stage 1 if your speedometer or odometer do not work.
You would have been charged either way, since they did the quick learn for the trans you get charged an hour of tranny tech time for them to do the programming.. So don't feel you got ripped or anything, it was really standard stuff. Just FYI
Just some general FYI for anyone thinking of a used S1 PCM. Call Flight Systems they do the programming for Mopar so they put the S1 data on the PCM and do transfer VIN#s to PCMs that are used. Yes they do charge for the service and it is COD only. But you can avoid some delay after you buy a used S1 if you have the seller drop ship to Flight Systems, they in turn ship to you COD only. The COD requirement is how I have always seen it done with them.
Call to confirm all information, since things may have changed since the bankruptcy.
Info is current as of Oct 7, 2008:
Flight Systems
33820 Riviera Dr
Fraser, MI 48026
586-888-0010
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
