Old 17 Jul 2009, 05:30 am
Alex_Clarke's Avatar
Alex_Clarke Alex_Clarke is offline
Default 2006-Up Pt Cruiser Spark Plug Removal.
This guide will work on PT's 2006 and up I think it might work on '05s and '04s as long as you dont have a modesty cover.
If you do have one of those go here:
Spark Plug Guide
I recently replaced the spark plugs and wires in my '06 PT
and I figured i would create a photographic guide for all you other '06 and up PT owners out there.
Tools you will need:
Most of the tools you should have if you have a decent toolbox.
Get some dielectric grease if you are replacing the wires. Unless the wires come pre-greased.
The Anti-Seize and the T-15 Torx can be found at most hardware stores or just look at Sears:
Sears.com/T-15
Well here we go:
First of all Remove the air-box...
Since I have a custom air intake I cant show you how to remove that,
but if you really, really, really can't figure it out all by yourself
(which if you cant you shouldn't have a car in the first place)
Heres a link: How to remove an air intake, PT-wikianswers.
After you have the intake off remove the three bolts located on the Throttle Body using the 10mm socket and the extension.
Then remove the five bolts on the front of the intake manifold
And the one large bolt behind the back using the 13mm wrench.
Also remove the MAP sensor using th T-15 Torx driver there is two screws.
Remove the vacuum hose from the side of the manifold by strongly and carefully pulling it off.
You don't have to remove the other one. I didn't, because it didn't want to come off.
So i figured i'd just leave it.
Now lay the manifold out of the way.
Cover the intake openings with a t-shirt or an old towel to prevent debris from falling in
Pull out the spark plug sides of the coil wires
And pull of the sides connected to the coil
Now you can remove the spark plugs.
Sorry I didn't tell you what size the spark plugs are but i'm sure you could figure it out.
You're welcome.
Here's a picture of the spark plug.
Put everything back together the same way it came apart (Torque specs for spark plugs are 13ft lbs) and don't forget some dielectric grease in the coil boots.
Originally Posted by CREWZIN
To end this thread I'll just go over why we recommend a small amount of Anti-seize be placed on the threads of the spark plugs and dielectric grease be put on both ends of the spark plug wires.
The anti-seize will stop the plugs from "sticking" to the cylinder block and make it easier for removal next time.
The dielectric grease with stop moisture from getting inside the openings of the plug wires, help make a better contact of the wires themselves and stop the wire ends from sticking so it will be easier to take them off at the next change.
Originally Posted by Hooligan
A hint for the next time you change plugs. Cut one of the "plug" ends off and use it to pull out and install the new plugs, they will self center and makes it easier to install the plugs.
Now pat yourself on the back and go get a ice cold beer Unless of course you arn't 21, then go get yourself a cookie.
Driver:Alex
Car:Petey
2006 Inferno Red PT Cruiser Touring Signature Series, 38K, 15mpg, Automatic.
Exterior:American Racing Estrella 16s, Toyo Proxes TPT, ROL Xtreme Exaust Tip.
Interior:Bumblebee BobbleHead, 2 6x9s, pioneer ts-g1640r's in doors, Parking Permit for my schoool.
Performance:Custom Air Intake, NGK Platinum plugs, Ceramic Brake Pads, Duralast 7.5mm coil wires, Duralast Performance rotors.
