Re: FM failure
Have never had to apply this logic to the PT, but in most cases there are two separate antennas for your FM and AM stations. The visible antenna on the outside of your car receives FM frequencies. I would check to ensure that your antenna is properly connected to your deck, and then also check to make sure that the connections to the antenna are still in place.
Are you using an aftermarket headunit?
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
