Old 20 Jul 2009, 08:34 pm
vadutchgirl's Avatar
vadutchgirl vadutchgirl is offline
Default Re: Overheating '01 Limited
Originally Posted by edsidders View Post
Mine did that after the fan quit and blew most of the water out,I was almost ready to pull the head but a couple of MGDraft's later I decided it had air trapped in the cooling system..It took a while and a lot of messing around but I FINALLY purged the air out of the cooling system and heater core,completely cleared it up.. It was puking water after running less than a minute to start with....
What did you do to get the air out? I have read that you have to get the front of the car jacked up and let it run at fast idle and then turn on the heat, let it cool off and repeat several times. Is there a better way?
01' Limited Ed.,(currently ill); '94 Del Sol
