Old 21 Jul 2009, 01:32 pm
edsidders edsidders is offline
Default Re: Overheating '01 Limited
Originally Posted by vadutchgirl View Post
What did you do to get the air out? I have read that you have to get the front of the car jacked up and let it run at fast idle and then turn on the heat, let it cool off and repeat several times. Is there a better way?
Not really, The funnel someone else mentioned would be a big help , Mine doesn't have the bleed screw someone else posted either..I have a fairly steep personal boat ramp in my back yard that worked just right... part of the problem was air trapped in the low place between the catch bottle and the chamber under the radiator cap.I also loosened the top radiator hose until it ran water under some pressure....loosening cap would have worked but the Sam Adams was beginning to work on me..I don't remember anything else I did..
All this brought back memories of my old t-bucket hot rod with a 409 chevy,the radiator had to be filled thru the hose to get it full and I built a radiator cap assy with upper hose attachment on a thermostat housing plate to make it work..
This Black Thing Keeps Chasing Me
YES ! That is a Ron Paul for President Sticker..
Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood
Ed Sidders , Lake-O The-Pines , Northeast Texas
