Re: Lube points under PT
If you are referring to the bushings on the lower control arms, yes they can be replaced. From the research that I have done, if your Crusier has "low" miles, they should be replaced instead of replacing the whole control arms. My PT is creaking and groaning going over bumps and it needs new bushings for the lower control arms. ptcrew.com has A LOT of info on this topic.
BTW, my car has a little over 49k miles on it.
