Old 22 Jul 2009, 09:15 am
mopar_man's Avatar
mopar_man mopar_man is offline
Default Re: Lube points under PT
Originally Posted by tandt14 View Post
From the research that I have done, if your Crusier has "low" miles, they should be replaced instead of replacing the whole control arms.
Even if it has higher miles, it shouldn't need the control arms replaced unless they're cracked or bent. My car has 120,000 miles on it and I just did the bushings about a month ago.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
