Old 22 Jul 2009, 09:21 pm
CREWZIN CREWZIN is offline
Default Re: synthetic trans fluid ok?
I had synthetic put into mine almost 40,000 miles ago. But here's something that said the regular ATF =4 is synthetic.
Chrysler ATF+4 (ATE) -- Introduced in 1998, ATF+4 is synthetic and replaces the previous ATF+3 fluid. Used primarily for 2000 and 2001 vehicles, it can also be used in earlier Chrysler transmissions (except 1999 and older minivans with 41TE/AE transmission). ATF+3 should continue to be used for 1999 and earlier minivans because of the potential for torque converter shudder during break in.
NOTE:Chrysler ATF+4 Must always be used in vehicles that were originally filled with ATF+4. The red dye used in ATF+4 is not permanent. As the fluid ages it may become darker or appear brown in color. ATF+4 also has a unique odor that may change with age. Therefore, do not relay on the color and odor of ATF+4 to determine if the fluid needs to be changed. Follow the OEM recommended service interval.
Chrysler ATF+5 for 2002 and newer models.
