Old 22 Jul 2009, 09:30 pm
CREWZIN CREWZIN is offline
Default Re: 2006 - Replaced Fan - Comperssor Not Working
There's two switches you might want to check out before blaming the computer. The High Pressure Cut-out switch located on the compressor and the Pressure cycling switch located on the accumulator can both cause the compressor to malfunction. The local A/C place should know how to test them.
