Re: Suspension problem, ticks and clicks
If you have a jack, you can look under the drivers side for a tear on the CV joint boot. That's what usually goes wrong, a tear in the boot leaves it open for dirt and debris to get inside and play havoc with the joint. It usually run anywhere from $100 to $200 to replace a single joint.
