Old 31 Jul 2009, 12:32 pm
slartyblarfast slartyblarfast is offline
Default Re: US vs Import Model. Difference?
Where are you located? If you are in the US then it's not imported. More likely the difference is SBEC or NGC. 04 was the change and it was a running change. Where is the crank sensor located? If it is on the backside of the engine then it is SBEC. If the crank sensor is on the frontside then it is NGC.
All PT's are made in Mexico. Imported means it went to somewhere other than US.
If I where you I would go to the dealership and get the part. That way you know for sure it is right. Also you get 12/12 warranty and free replacement in that 12/12. May cost a little more but worth it!
