Re: Help! Timing Belt damage
Originally Posted by slartyblarfast
Bottom line is you won't know till it's torn down.
Pretty much and even then it might not be totally obvious. I had the timing belt in my car break and I couldn't tell if everything was alright. I took the complete head to a local rebuilder and had it checked out just to make sure no valves were bent or any guides got buggered. I think it cost about $200 but I'd rather that than take the whole thing apart again to find that what looked OK turned out not to be. If you would rather skip the head check, you can get a rebuilt one on eBay for under $500: link.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
