Old 02 Aug 2009, 10:25 am
ratnin57 ratnin57 is offline
Default Re: 2005 2.4 Turbo stalls sets code P2305
Ok I will try a coil capacitor. It must be a dealer item as I can't find it on local auto parts store sites. Below are possible causes for setting code P2305 from a pay site. I'm assuming that if this capacitor quits it kills the coil.
WHEN MONITORED
Engine Running.
SET CONDITION
If PCM detects that the secondary ignition burn time is incorrect or not present an error is detected. One Trip Fault
POSSIBLE CAUSES
* Intermittent condition
* Spark plug
* Ignition wire
* Ignition coil operation
* Ignition coil control circuit open
* coil control circuit shorted to ground
* PCM
* (A142) ASD relay output circuit
* Ignition coil
