Old 02 Aug 2009, 11:41 am
CREWZIN CREWZIN is offline
Default Re: 2001 Limited fog lights don't work
Welcome to the forum.
You don't say what year you PT is and it makes a difference. If it's between 01 and 05 the #8 fuse is for the fog lights. If someone took it out it's because of a bad multi-function switch (the one that controls the lights). They tend to burn out and either the fog lights will stay on all the time or the switch will start to smoke.
If your PT is newer, there's no fuses in the interior of the car and none of the listings for the fuse panel in the engine compartment say they are for the fog lights, BUT the problem with them not coming on is probably the same as before: a mad multi-function switch.
