Old 02 Aug 2009, 12:25 pm
CREWZIN CREWZIN is online now
Default Re: radiator fan removal on 06 up cruiser
I wrote the sticky. There shouldn't be a whole of of difference between mine and yours. Take it slowly, look around at each thing your taking apart before you start unscrewing or pulling. After you take the the top radiator support and front grill off, the hardest part for me was the horizontal bar across the front of the radiator. It was held on by two bolts on either end that were hidden and a lot of trouble to get to. The radiator has to tilt forward so the fan housing can lift up and that bar is in the way.
Also, on the electrical connection from the wires of the fan. There's a red slider lock that slides to the right to unlock the connection and then a small U shaped clip that has to be lifted up so the connection comes apart. I added another picture to the sticky showing the electrical connection.
