Re: radiator fan removal on 06 up cruiser
Another way if you have old anti-freeze is to remove the bottom radiator hose and pull the fan assembly out from the bottom. But make sure the anti-freeze is cool and then put in new when you are done. 2 birds 1 stone.
You can disassemble an entire PT with a 10mm wrench. So where did it go!
