Old 02 Aug 2009, 05:09 pm
85_305 85_305 is offline
Default Re: Read threads for hours!
Where to begin where to begin...
If you have a bit of money (couldn't tell you how much.. I haven't done any research.. YET), but cams and an intake and chip are the BEST things you can do for the money. Aftermarket cams will yield better gas mileage AND more power.
But for right now, here is what you need to do. Flush the trans. Put synthetic motor oil in, get a SRI (buy the biggest filter, either K&N or AEM or APC you can find, and put that on to the end of the bendy stock intake pipe), buy better plugs and gap them correctly, buy better wires and maybe even a coil, and check your tire pressure. I typicall go about 5psi over the max load (read the tires for how many psi they require, then add 5). That should get you off to a good start.
Silver 2002 pt cruiser touring edition, auto, dark ass tint, 89k miles... shift burp mod, SRI
2005 civic ex special edition, 5spd, fully loaded, 40k miles
I have a wide-band o2 sensor for sale!! PM ME!!
