Old 03 Aug 2009, 09:34 pm
eflyguy's Avatar
eflyguy eflyguy is offline
Default Re: How do you remove the dash top panel?
Well, I got impatient and pulled it just now. Took all of 5 minutes - would have taken 2, but the link above does *not* apply to my 2001. You have to pull the center dash panel (air vents/window switches), which requires you pop the switches out and remove a screw. Once that panel is removed, you have to remove two screws that hold the dash center to the frame that supports the center panel.
I'll take some pics in the AM..
..a
2001 Limited, stock except for burp-shift mod & K&N drop-in for now..
Replaced: fan assembly, plugs and wires, battery.
