Old 14 Jun 2003, 06:24 pm
RetroPT RetroPT is offline
1MEANPT, I'd think twice before ordering from DZMotorsports. The Drop Zone equipment in the most part is fine. I found the tubing supplied to be of a low quality and replace with a heavier walled (few leaks around the fittings (also less time the compressor runs, mine was original kicking in every 10-15 minutes). The supplied solenoids leaked, both on the inlet side and outlet side. so in some cases the ride would rise as I drove along and at other times the ride would lower.
The personnel at DZ are not the best when it comes to customer service and support, calls were never return, delivery promises never kept. My PT spent an additional 5 days in the ship waiting for exchange parts to arrive.
the Struts in the front are approximate 1" lower than the stock assembly when fully inflated so it will not end your scrapping problem. So again THINK TWICE before using DZ Kits. Find a local shop who specialize in Air Suspension, they generally backup the install with little or no additional changes and if you have it install by some one elese your kit is generally not backed up.
RETROPT - 2001 PT Sedan Delivery
