Thread: Buy or run?
Old 05 Aug 2009, 09:28 pm
Mean Green Mean Green is offline
Default Re: Buy or run?
Originally Posted by quicksilverdon View Post
It's a timing BELT. It should be replaced (water pump at same time) by 100,000 miles. It costs $700 - $1200 to replace.
The auto should be flushed every 50,000 miles - flushed by a flushing machine to get all the fluid - and be sure they use ATF+4 - runs approx. $200.
I'm just giving you things to expect. If they fix the other issues, you should be okay.
I'd change the oil as soon as I got it (so then you know when it was changed and what is in it, and do the wires and plugs (get aftermarket wires) - stop in if you get it...
Good way to lose your auto tranny as I did in my '01 at 81k. Every 30k alternate between a drain/fill and a full flush. This was told to me by the service mgr at my dealer when I questioned him about the crappy 41TE going out in my '01. No problem with my wife's '04 auto tranny with the alternating 30k schedule. The car now has almost 124k.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
