Re: Installed Hurst Shifter in my GT and now it wont go into reverse!
Did you check the crossover lever spring for correct orientation? I installed mine last week and minus one bloody knuckle it went well! I assumed the ends of the spring sit on either side of the head of the allen bolt rather than on the thread as there is no instruction either way. Seems to work fine. Also, the e-clip was a pain but there is one position it finally worked in.
 2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
