Neon95,
Another option is to sell your stage 1 and purchase the SCT XCal2 unit with a 93 octane canned tune from SebringLX over on PTCrew.com. It is a limited time offer. Josh (SebringLX) starts with the Stage 1 code (including the highly desirable auto trans shift improvements) and ups the ante with a tune that peaks 17psi falling to 15ish at redline. It is $175 for the XCal2 and the tune. This will give you better than stage 1 performance along with the auto trans improvements that no one else has. You also can do proper tuning later if you desire. No more map clamps and fooling the PCM. No more PCM retarding the timing when it sees more boost than it wants. You'll want to keep the larger injectors for this tune. The SCT works with your stage 1 PCM as well if you wanted to keep that.
My unit is on the UPS truck to be delivered today.
Brian
