Old 06 Aug 2009, 10:58 am
mopar_man's Avatar
mopar_man mopar_man is offline
Default Re: Problems with new style tensioner
Good to hear you got it on. I struggled with mine too. I had to remove and replace it 3 times because the cam gears moved putting it on. It didn't look like it when the belt was on but after rotating the engine a couple times, the marks didn't line up.
You replaced your water pump while you were in there too didn't you?
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
