Car died, wont start! HELP PLEASE!!!
Ok so driving car down the road and it spits sputter and dies....RPMs go crazy at the same time. Oil light, check engine light come on. Chack with scanner and come up with Camshaft position sensor, ignition control, engine speed sensor, and tranny mang. I cleared the codes and checked the Timing belt thinking that went. No go looks good. I have 60 psi @ fuel and i have spark. When i got it home and let it sit for a week it fired right off and than dies....started up again and does same thing..get progressivly worse(not running as long) Now i can crank and crank but will not even pop. Camshaft position sensor code is the only one i am getting. Replaced that part and it still will not start. Anybody have any ideas?!?! Any help is great!!!!!!!!!! Thank you!!!
