Re: EGR valve 2003 GT Turbo
The 03 GT doesn't have an EGR valve. If you are still using stock plug wires get rid of them. I'm using Bosch Premium plug wires with a life time warranty. I don't like champion plugs as they leak, and went to NGK 2315.Tie wrap all vacuum lines, especially down by the turbo and brake boost. One reason I went with the plastic intake manifold is the o-rings instead of the gaskets used on the aluminum manifold, and less heat sink.
