Old 08 Aug 2009, 04:18 pm
03hothemi's Avatar
03hothemi 03hothemi is offline
Default Re: A/C blowing warm then cold idling & overcharged!!!
The cooling fan should not kick on and off with the air conditioner on. If the air conditioner is on, the cooling fan should always be on. If the cooling goes on and off with the a/c on, you most likely have a bad cooling fan. IIRC, low speed goes on and off with the engine temp, and high speed is always on if the a/c is on.
2005 PTC Limited N/A- All Stock...for now
2003 Hemi Ram - TMR, Flows, Killed the Cat with mechanical O2 sim, K & N, no hat, Taylor Shorty Wires, Tow Pkg
