Originally Posted by 03hothemi
The cooling fan should not kick on and off with the air conditioner on. If the air conditioner is on, the cooling fan should always be on. If the cooling goes on and off with the a/c on, you most likely have a bad cooling fan. IIRC, low speed goes on and off with the engine temp, and high speed is always on if the a/c is on.
What's not making sense is that the fan turns on when the pressure gets high and turns off when it lowers it to the correct pressure. To me it seems it could be the switch malfunctioning and not turning the fan on earlier because the switch is telling it to turn off. From my experience when a fan goes bad it either just stops or spins erractically and stops and does not perform the function of cooling down. My fan is cooling down the pressure but it isn't being told to react quicker. Since the switch is easiest I'll do that first and keep ya guys posted....
66CUDA
